gauges questions - Ford Powerstroke Diesel Forum
Old 10-29-2010, 11:13 PM
shhhhh, can you hear it?
Question gauges questions
ive done a lot of reading on this form and ive never seen this approached so im going to.for those guys using tuners on your trucks,these tuners monitor the stock pyros in the manifold and for you spartan guys the ones in the dpf/doc;so is there a need to add another pyro gauge on the a-pillar?i would think you could use that spot for something else.i know the h&s monitors the ones from the manifold and i think there is one after the turbo it monitors also (not sure on that one).so why tap your manifold for another one?instead you could have something like a diff or transfer temp gauge.just putting it out there to get some opinions,let me know what you think.
Old 10-30-2010, 01:00 PM
its not needed but i have all three A pillar gauges and my dash daq. my A pillar pyro reads between 50-100 degrees higher than my dash daq gauge. i have it just so i can watch it when im not using the das daq
Old 10-30-2010, 10:39 PM
which one is more accurate?im just thinking maybe i can put a different gauge there that the tuner doesnt monitor ya know?but what would i put there?transfer case temp,rear diff,flux capacitor meter?
Old 11-02-2010, 12:47 AM
bump
Old 11-04-2010, 09:36 AM
personally i think the mechanicals are more reliable/accurate. but i have compared the three i have to my dash daq and the dash daq is just as accurate.
Old 11-04-2010, 09:53 AM
I vote flux capacitor meter. Anything under 1.21 jiggawatts and you're going to have problems. It's well documented.
Old 11-04-2010, 11:04 AM
thats what i was thinking chris
Old 11-04-2010, 12:55 PM
Its the least I could do, Patty
Old 11-04-2010, 10:28 PM
at least you contributed in some small way.lmao
Old 11-05-2010, 03:24 AM
I have an H&S mini, the unit has various items it monitors thru the OB port. I have mine set to monitor things that do not show up on the stock instrument panel:
Exahust temp
Percent Throttle ( I use this one to try to keep the mileage up)
Voltage ( Battery)
Inlet Air temp.... I would like to see Oil Pressure in this place)
cheers
