SCT Livewire Extreme Settings Questions
I have a few questions with the SCT Livewire Extreme Offroad with DPF/CAT delete.
1. I have 4 different EGT PID's. One says PEGT then EGT1, EGT2, EGT3 2. Are all of these in Celcius or Fahrenheit? 3. If using the SCT canned Extreme tune should you still disable the EGR even if you don't have a EGR delete kit or blocking plates installed? Thanks for your time! |
the PEGT is in deg F and the other three are in deg C
and i turn off the egr with my tune and i dont have the plates installed. |
I use PEGT in F, never tried the other 3 as i think they are the sensors that are in the dpf delete pipe.
I run with mine enabled because I have not deleted my egr. I ran for a few weeks with it disabled but want the egr to still cycle at idle and such. |
