?'s about my H&S
How do you turn the EGR off.... And what should I set my defuel par. at? I have NO! knowledge of Defuel settings at all...
If you are running the DPF delete tuning , the EGR is disabled in that tuning. As for de-fuel parameters for EGT, I would leave it at the factory default of 1450 degrees.
Defuel simply equals stock HP. I have mine set at:
Boost = 38 (careful, don't want to blow a head gasket/stud/etc) Coldcoolant = 170 (let it warm up before throwing the HP to it) Oiltemp = 210 (don't overheat the engine) Transtemp = 210 (don't overheat the trans) EGT = 1250 (don't melt the car beside you) Sig |
Boost= 48
EGT= 1500 Trans= 210 Hot Coolant= 210 Cold Coolant= 150 I have heard you can run the egt defuel safely at 1600 but that just seems a little excessive to me, I can usually finish a 1/4 without hitting the defuel at 1500 |
I am purposely being over cautious with my parms. The main purpose I tuned mine was for MPG but do get a little "gitty" with it occasionally so I "ration" myself...
Sig |
I like melting cars... just like I roasted a Benz SUV yesterday
