This is for those of you with Job 2 trucks and newer with Level 3 Tier licenses (already have the 275, 310, and EGR delete tunes). If you want the 300 tune you must do the following....
Send an email to Mick at tech@spartandieseltech.com with your Name, DashDAQ SERIAL #, and who you purchased the tuner from. IF you did not purchase the tuner through Spartan, you must fax us (or email us) a signed "Off-Road Tuning Disclaimer". The fax number is 828-692-9968. NOTE - Let Mick know in your email that you are wanting to update the tuner and get the 300 tune. This way he will know what the email is regarding. Just a heads up. When you do this, your tuner will also be getting E-Motion's latest software for the DashDAQ. This means that all of your old tunes will no longer work, BUT you can get Mick to remake you an old tune that you have as an .ENC file at no charge. ALSO, if your tuner is strategy flash you will need to send Mick your original stock file. Make sure you do this because it will no longer work with the update. Job 1 files are still in testing and should be available soon! Thanks, Jeff@Spartan |
bought my tuner from powerstroke magic so i guess i have to sign the waiver and send it to yall?stupid question i guess since u said if you did not buy the tuner directly from yall line
also the strategy flash is the dashdaqs with the stock tune to 250 tune right? how do u send the stock file?
Yes, strategy flash tuners have all of the tunes. You have to have a Level 3 license to get the 300 tune though as I stated in my original post. |
I have three tunes with tire recalibration. Can I get those again? What about getting the 300 tune recalibrated for tire size? I'm sure this thread is fixing to hit you with a lot of questions and I would like to say now Thank You for your time!
My recommendation for you is to send an email to Mick and explain what you are wanting to do. I would think that since you already have paid for tunes adjusted for tire size, you will get those free as .ENC files after the update. You will be able to get the 300 tune adjusted also, but you would have to pay for it of course.
New update sounds like it sucks. Can't load your stock file anymore?? This can't be right?
I think he is saying send your original stock file so that Mick can put it in with the update and you would have the stock file then. I'm not sure but that is what I got out of it.
So if I buy the 275, 310 tune will it also come with the 300 tune?
