H&S Defuel Parameters - Ford Powerstroke Diesel Forum
post #1 of 15 Old 10-16-2010, 07:22 PM Thread Starter
shapiros's Avatar
What do folks set their defuel parameters to on their tuners? Want to keep it running safely...
Sig
2010 F250 FX4 Sterling Grey CC SB 3.31 Gearing
  • 20" Pro Comp Wheels
  • 34" Nitto Terra Grapplers
  • Ionic step bars
  • Husky Liner mud guards
  • ReadyLift leveling kit
  • UWS toolbox
  • LineX bedliner
  • AVS vent shades
  • H&S Mini Maxx Tuner
  • Flo-Pro DOC/DPF delete
  • AFE Stage 2 Pro 5r intake
  • HID Bi-Xenon 55W, 6000k temp headlights
  • Complete LED interior/exterior lighting including front switchbacks
  • Webasto 4300 sunroof
  • AmSoil (engine, trans transfer and diffs coming)
shapiros is offline
post #2 of 15 Old 10-17-2010, 03:21 PM
09monster's Avatar
Just left mine with how the factory had it set on the tuner
09 F250 SC/SB, 10inch Fabtech Susp., 38x15.5x20, 20inch Novakanes, Blackmaxx mini, AFE Stage 2, Doc/DPF delete, MRBP duals *sold*
2012 F250 CCSB Stock as of now
09monster is offline
post #3 of 15 Old 10-18-2010, 08:32 AM
joec410's Avatar
Quoted: 2 Post(s)
I am interested in this also, what is the maximum boost that the headgaskets can handle on these engines? I know the EGT's setting is 1350 and the transmission is 210, but I am unsure of the maximum safe boost numbers, I have mine set to defuel at 38 PSI.
joec410 is offline
post #4 of 15 Old 10-18-2010, 09:15 PM
I have my defuels set at 1400 EGT's, 36psi boost (more worried about drive pressures than boost), 210 trans, 210 coolant hot, 130 coolant cold
I'm running H&S smaller tunes in my Black Maxx (0, 40hp, 80hp, 130hp), so EGT's aren't really a concern, but the boost will still get up there...
2002 LB7 Duramax
RockinJW is offline
post #5 of 15 Old 10-19-2010, 08:44 AM
powerstrokedub's Avatar
My defuels are very similar to rockinjw, except, cold coolant 160, max boost 38, and egts 1250. I am running the h&s mild tunes (80,150,225). I did take my defuels off the other night and ran the 225 hard for about three pulls. Max egt was 1650 and boost saw 46 psi. These bigger tunes from h&s definately push the truck hard so I would watch out if you guys are choosing to manually defuel your trucks..
I doubt I will ever run my truck that hard again but I wanted to see where the upper end of my hot file was.
2010 6.4L CCLB
2007 6.7L QCSB
powerstrokedub is offline
post #6 of 15 Old 10-19-2010, 08:46 AM
Jacob, is there anyway to monitor engine back pressure on the black maxx?
Also I was seeing 34 psi boost stock, so I figured another four pounds would not be too big of an issue, what were you seeing stock boost wise?
2010 6.4L CCLB
2007 6.7L QCSB
post #7 of 15 Old 10-19-2010, 09:31 AM
Don't know on stock boost, truck had just 126 miles when it was deleted and tuned
2002 LB7 Duramax
RockinJW is offline
post #8 of 15 Old 10-19-2010, 10:57 AM
joec410's Avatar
Quoted: 2 Post(s)
I am also running the Mild tunes (0, 80, 150, 225) and I am using the 80hp setting. I have had it on 150 hp setting once and I have never used the 225 hp setting Please explain drive pressure? What are you refering to?
joec410 is offline
post #9 of 15 Old 10-20-2010, 08:12 AM
That's what we like to hear!! Haha
Back pressure is the pressure against the motor due to exhaust not being able to escape the turbo fast enough, or at least that is my understanding of it.
If it gets to high pressure in the cylinders will be great enough to stretch the head bolts and pop the head gaskets causing the infamous "puking" scenario. I don't think on the 225 file there is too much to worry about. Most head gasket issues I have read about have been on 275+ files.
2010 6.4L CCLB
2007 6.7L QCSB
post #10 of 15 Old 10-20-2010, 12:37 PM
So if I am running the 0hp tune (Just using to delete the DPF) I should be pretty safe using the stock defuels?
1stgear is offline
