Help!
i got a my tuner today... tried installing my exhaust... the old exhaust bolts will not come undone and there also is no cheat sheet in the box how to do it ... it is a 4inch flo pro complete exhaust dpf and cat
any help on how to do this would be great!!!
Just installed a Flo-Pro DOC/DPF delete. What specifically won't come undone? There is no such thing as a bolt that won't come "undone", just what it takes to get it undone...
Sig |
the bolt that attaches the downpipe in to the exhaust!!! we stopped there cause it would have snaped and and rounded off the bolt.....
any pointers on doing the whole job would be great!! |
bolts are so rusted truck has 52k on it
WD-40, just a thought.
James. |
Spray the hell out of the bolts/nuts with WD-40 or other penetrating oil several times and let it sit over night. Hit it again the next day.
![]() If that does not work, a Dremel and cutoff wheel will do the trick. Sig |
A common mistake is that guys will try and take the bolts out from the rear side of the flange the nuts are welded on the bolts come out of the front side i did it then figured it out. so if that is the case try the other side!
Chris |
got it installed!!!! when running what is the burning smell?
