6.4l egr delete install - Ford Powerstroke Diesel Forum
Old 10-14-2010, 06:09 PM
I bought a kit from a forum member who was getting rid of his truck. I have the elite egr delete with wastegate and looks like most of the pieces, but i have no guidance on install. If anyone has a installation sheet or a write up it would be greatly appreciated.
Old 10-14-2010, 06:39 PM
For an easy install, I would recommend pulling the cab. It would be a major PITA if you tried to do it cab on. Also, depending on which kit it is, you might need to do some welding. Where are you located? You might want to have an experienced shop do the install.
Old 10-14-2010, 07:18 PM
I have all the pieces and stuff fabricatated including the down pipe since he already welded in place. Just need a general run down on what all has to happen should be pretty easy install
