My truck is idling high with the H&S mini maxx.
Truck will idle right for maybe 30 seconds or so and then it will start idling high. Right under 1000 rpm. If you hit the peddle just for a second it it will come out of for awhile and then it will eventually idle high again. Any ideas? Truck has 5k on it and has had the H&S for about 4k miles and has never done this until the last 500 miles or so. Any help is greatly appreciated!
What are the outside temps?
Much colder than it has been. 40s in the morning and 60s during the day.
Is it doing it all the time, or only in the cold mornings?
Well morning is when i let it idle the most warm up. I will try and see later in the day tomorrow.
Whats odd is that it idles normal for a while. And will idle normal again for a while after you tap the throttle. |
Sounds like cooler weather high idle to me.
08stroker250 Sounds like cooler weather high idle to me.
Ditto on that. |
So would it do this stock as well?
yup, mine did that when it was stock.
ya its just the cold! happened to me last night, no worries!
