60hp injectors - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-04-2010, 04:47 PM Thread Starter
11SuperDutyKR's Avatar
60hp injectors
can I add just the elite 60hp injectors w/o adding a fuel pump and increase power? just idea, don't bash if won't work
-Adam
2008 Dark Shadow Grey F250 CC SB
Mini Maxx(KEM tuned), S&B, 4'' DP, 5" Straight Pipe, CS IC Pipe, Readylift w/ 35x12.50 toyos on black 20's, OUO traction bars & blocks, Westin Black Bull guard w/ KCs, UWS Toolbox
2011 F250 KR CC FX4 3.55 rear, AFE Intake SOLD
11SuperDutyKR is offline
post #2 of 4 Old 10-04-2010, 07:24 PM
08stroker250's Avatar
You will need at least the Elite HPFP upgrade, and it will all need to be supported by there stage II low pressure system if you want full potential.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #3 of 4 Old 10-04-2010, 10:45 PM
KTMotoRider1's Avatar
It seems to me with the amount of smoke and EGT that these 300+ hp tuning files make the best way to make power is with airflow improvments in the form of intercoolers, turbos, manifolds etc......adding more fuel to the mix will just make these things run even hotter. Move to fuel later on
Ford F250 6.4 CC/SB, Spartan 350 w/TCM, Mag-Hytec deep pan, Flo-Pro 5 inch Exhaust, AFE stage 2 with ProDRy, 2.5 Readylift, ZEX Nitrous single stage, BD CAC pipe, ATS 5-star converter, elite egr delete/wastegate, ts mp-8 stacked, Procomp traction bars, locker, CFM plenum, ARP studs. Innovative tunes and Suncoast on the way!
KTMotoRider1 is offline
post #4 of 4 Old 10-05-2010, 11:52 AM
Rudy's diesel performance's Avatar
Yes they will increase power slightly just because of the 8 hole design and better spray pattern. However, you will need custom tunes to maintain rail pressure.
Sales @ Rudy's Diesel Performance
*CONTACT US FOR SPECIAL PACKAGE DEALS ON SPARTAN, SCT AND H&S PERFORMANCE DPF/CAT DELETE KITS*
(919) 383-9300 OR Toll-Free # 1-866-757-6537
Rudy's diesel performance is offline
