elite fuel system
Anyone install a fuel 6.4 system on 6.4 from elite. I have questions/problems, installing the parts to the HPFP. The instructions on steo 48 state that in order to have the least restriction the feed line should go direct to the HPFP. I have the stage 2 kit and seems the instructions for that part a very vauge or nonexistent. Need help Fast. Thanks
is the upper filter housing not used with the kit? Does the regulator block bolt into its place?? The bolts that mount the bracket to the regulator hit the intake??? Please need help asap....
Im courious about this also. There are many smart guys on here someone will know.
I figured someone would know. Maybe there are not many people running there fuel system.
Got the kit installed, was NoT impressed with the instructions...... Kit has good quality, instructions had much to be desired.
