Bung on Flo-Pro Exhaust, Function?? - Ford Powerstroke Diesel Forum
Old 09-17-2010, 11:16 AM
I just noticed a bung that has a fitting that allows you to slip a hose on to it. What is this fitting for? Mine is just open and I suspect that exhaust leaks thru there and will eventually make the undercarraige very dirty. Is there supposed to be a hose connected to something here, or can I just cap this? Thanks in advance.
Old 09-17-2010, 02:00 PM
The bungs are for your sensors. Probably the pressure sensor bung.
Old 09-17-2010, 02:53 PM
This isn't the type of bung for a sensor. It's a male nipple for a hose to slip over. The other sensors are in and connected.
Old 09-18-2010, 11:27 AM
Like 08 stroker said. theres a hose that is for the DPF pressure sensor. it has a bracket that bolts to it as well.
Old 09-18-2010, 02:26 PM
take that out and bolt the hole up...it doenst get used,make sure you block the hose too..the bracket,just zip tie to the frame out of the way...you have all 3 other sensors in?
Old 09-18-2010, 06:04 PM
I'm going to cap it tomorrow. I'm still stuck with the pressure sensor CEL though. All 3 other sensors are in. Thanks guys!
Anyone know how to check the wire to the pressure sensor to know it's good?
