Detectability of Aftermarket Clutch - Ford Powerstroke Diesel Forum
Old 08-30-2010, 10:29 AM
I am currently running dpf/doc delete with spartan tunes, but I have a service contract with Ford, so I will need to put the truck back to stock before each oil change and service. The power increases through the Spartan tuner are just too much for the clutch.
I have been looking at the Southbend Dual Disc set ups, and they seem to be one of the better options for the ZF6 trannies. My concern is that when I take my truck in for service that someone will notice how heavy the clutch pedal is, and take note. Is this worthy of concern?
Thanks.
Old 08-30-2010, 11:12 AM
You could just tell them you tow heavy and wanted to the aftermarket clutch for reliability. The only warranty they can void is your "tranny/clutch" warranty.
Old 08-30-2010, 07:06 PM
They will not warant the clutch, and it is none of there concern that you already burned up the first clutch and had it replaced with a heavy duty one.
Old 08-31-2010, 07:49 AM
With an aftermarket clutch like the South Bend, you shouldn't feel that much of an increase in the pedal pressure if it's installed correctly. They don't physically press tighter together, they just have better friction materials. Out of curiosity, what tune could you run at most with the manual trans without slipping. I've got a manual and am waiting on Spartan to write the tunes.
Also, if anybody else can chime in that knows, I've heard that a South Bend or Valair (if they made one for the 6.4) are substantially louder than the stock clutch. You get the real diesel rattle, or so I've heard. I don't want that but I'd like a better clutch. Anybody know if this is true?
Old 08-31-2010, 10:34 AM
Dual disc clutches can be loud. I don't know if Valair makes anything for the 6.4. Southbend might have a single disc (can't remember), but it isn't going to hold up with the bigger tunes like a dual disc.
Old 08-31-2010, 02:06 PM
South bend does have a dual disc with Feramite friction material. I've heard there unbearably loud.
Old 08-31-2010, 03:29 PM
im running the single disk "feramic" from south bend. seems to be holding up to the 250Hp Spartan, but I find the clutch "harsh" It wants to be in or out, no slipping.
Old 08-31-2010, 07:55 PM
Did it make any difference in the engine noise. Like "rattle" from the clutch at idle or any other RPM? I need to get something, but if I do, I'd like it to be able to handle the larger tunes from Spartan, like at most the 310 tune.
Old 08-31-2010, 08:18 PM
The stock clutch isn't good for any of the tunes above 150. My clutch slipped whilst towing on the 150 one time under medium load. I should add that my truck has 20k easy miles on it so far. Does ford offer any factory clutch upgrades?
Old 08-31-2010, 09:04 PM
Powerstroke Techie
Very good friend of mine has a 210 tune in his truck and the stock clutch slipped. He's now got a South Bend Dual Disc in it. Thing grabs AWESOME. Clutches aren't warrantied much anyhow, they are a 'wear item' like brake pads.
Likely, the Ford dealer will tell you your throwout bearing is going away with the dual disc South Bend.
And yes, the dual disc South Bend clutch is NOISY. But only with the pedal pushed in. Driving down the road it's no different than the stocker.
The SB clutch, I noticed, as well as my friend, is VERY grabby. This isn't a fault per se, it's just the way it acts. It's very chattery getting the truck moving, even for someone that's driven stick forever. Fantastic product though, very very nice pieces. HEAVY... Holy GOD is it ever heavy. I think the shipped weight was about 140lbs. Comes with PP, flywheel, disc, secondary disc.
PM me, I have some additional information that you might find useful.
