buying AFE exhaust to go with H&S, what thread for sensors? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-24-2010, 08:59 PM Thread Starter
I'm ordering the AFE full downpipe back exhaust and my H&S is on the way, can anyone tell me what thread the dpf sensors use since I will just plug them and leave the sensors in my dpf?
Also, can anyone tell me if the afe exhaust has the pressure sensor nipple as well as the 2 threaded bungs?
Thanks
DG500 is offline
post #2 of 5 Old 08-24-2010, 11:06 PM
well from having to go through this myself I can tell you, 3 of them are 12mm fine thread, get the shortest bolts you can find. I think I ended up with a 12mm x 30 and it worked just fine, then there is the one crazy can't find the right size bolt. I thing it is the pressure sensor but I'm sure someone can correct me on this. I could not find a bolt that fit it exactly and this is going to 4 different fastener speciality shops. I ended up getting a 14mm fine thread which will thread in just a little bit, maybe 1\4 of the way, and a matching nut to get a good jam thread effect going on. It has worked perfectly for me and does not ruin the threads on that oddball thread, which should be a 13mm fine thread if you are so lucky to find a shop that carries one. Good luck and bribe a buddy to help you lol
t.c.ben is offline
post #3 of 5 Old 08-24-2010, 11:08 PM
Ohh yea I used the afe pipes and they have bungs for all of the sensors, I just unplugged them all, make sure you get some dielectric grease to fill the sensor plugs left on the truck so they don't get all jacked up
t.c.ben is offline
post #4 of 5 Old 08-25-2010, 04:49 AM
Dim Sum's Avatar
Send a message via AIM to Dim Sum
I covered mine with plastic and zip tied them. Dielectric grease sounds like a better plan.
Thanks for the tip.
-Steve
2011 F-350 Lariat 4x4 SuperCew: White Platinum Tri-Coat, Goodyear Wrangler Silent Armors, Window Tint
2001 Hyundai Elantra: Daily Driver
2007 Polaris Sportsman 700: Weekend fun!
Dim Sum is offline
post #5 of 5 Old 08-26-2010, 06:20 AM
John@CDP's Avatar
The bolt size is 12mm x 1.25 thread pitch, buy the shortest you can find which will probably be around 20mm long. Let us know if we can help!
John Cobb - Owner of Cobb's Diesel Performance
Email:
CHAT LIVE WITH US FOR REAL TIME SALES QUESTIONS & TECH SUPPORT ON OUR WEBSITE!
John@CDP is offline
