Just istalled Spartan tuner exhaust and intake
Just installed Spartan tuner an exhaust started right up and ran great turned truck off an now won't restart and Check engine lite is on and can't get to clear need help
try reloading the stock tune, but dont start it. then reload the tune you had on it and see if it will start up after that..
Thanks I'll try that also the flo pro exhaust that I got didn't come with the bungs either, does that make any diffance
Um...yeah.
You need bungs, and the EGT sensors must be plugged in. That is your issue most likely, you didn't plug up one of the sensors....or all of them.
If I just plug the sensors in but don't have them mounted to the exhaust will that be ok. Cause the people who sold me the exhaust said I didn't need the sensors, installed on the exhaust
Yes, plug the sensors in and tie them in to the frame rail. Who did you order from? I would make them send you a pipe with bungs free of charge!
Ok so plug them and should I go back to stock and then go back to what ever tune I want? Diesel power products
Plug them in and retune the truck with the same tune. That should work since it will flash the ECM again.
