spartan 150... - Ford Powerstroke Diesel Forum
post #1 of 11 Old 08-09-2010, 07:09 AM Thread Starter
strong_j's Avatar
spartan 150...
Hey does anybody run the spartan 150 dpf on tune??
I was wondering if this is a tune that is ok to run on all the time??
Ive head mine on for about a week and just yesterday i got a "pull over safley now" light on my dash and the damn truck just shut off and would start!!
i resetted it to the stock tune and she fires right up and drives fine.
I was wondering maybe if i dd on that tune it was clogging the dpf and sensors or was it something else??
thx
08 HD f250
"having a 9 sec ricer is like coming out of the closet for the first time. at first everybody is all shocked and in awe, but at the end of the day your still gay"
strong_j is offline
post #2 of 11 Old 08-09-2010, 09:42 AM
KTMotoRider1's Avatar
Im assuming this occured during a regen cycle? I had this happen to me a couple times when I was running a bully dog pmt. I believe its due to egts being out of acceptable range. Im not sure but I think it can be caused by a bad DPF which seems to be a pretty common problem.
Ford F250 6.4 CC/SB, Spartan 350 w/TCM, Mag-Hytec deep pan, Flo-Pro 5 inch Exhaust, AFE stage 2 with ProDRy, 2.5 Readylift, ZEX Nitrous single stage, BD CAC pipe, ATS 5-star converter, elite egr delete/wastegate, ts mp-8 stacked, Procomp traction bars, locker, CFM plenum, ARP studs. Innovative tunes and Suncoast on the way!
KTMotoRider1 is offline
post #3 of 11 Old 08-09-2010, 09:51 AM
Koda22's Avatar
Quoted: 5 Post(s)
so a broken dpf would cause that porblem?
Koda22 is offline
post #4 of 11 Old 08-09-2010, 10:12 AM
powerhoghp's Avatar
Yes, but it could just be needing a regen. However it cannot regen if egts are above a certain level. Tuning raises egts enough that during driving, it can be "out of acceptable range".
powerhoghp is offline
post #5 of 11 Old 08-09-2010, 10:25 AM
08stroker250's Avatar
Did you check for codes when this happened?
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #6 of 11 Old 08-09-2010, 11:40 AM Thread Starter
strong_j's Avatar
No i didnt get the codes was my first reaction was to put this **** back to stock as quickly as possible!! lol
So the best idea is prolly not to use the 150 as a DD tune.
08 HD f250
strong_j is offline
post #7 of 11 Old 08-09-2010, 08:10 PM
Coffaro's Avatar
I had the same problem with all the Spartan tunes with the regen on. I just put my truck back to stock for now.
Coffaro is offline
post #8 of 11 Old 08-10-2010, 07:01 AM
John@CDP's Avatar
I have personally never ran a DPF-on tune from anyone on my truck but I have had several customers run the Spartan 150 tune for a week or more until they have the time to install there delete pipe and I have never heard any issues. You may see an increase in regeneration cycles per tank of fuel due to the increased soot load. Typically the "please pull over safely!" message is a result of a bad DPF Tempurature Sensor.
John Cobb - Owner of Cobb's Diesel Performance
Email:
CHAT LIVE WITH US FOR REAL TIME SALES QUESTIONS & TECH SUPPORT ON OUR WEBSITE!
John@CDP is offline
post #9 of 11 Old 08-10-2010, 07:24 AM
Superstrength08's Avatar
i had this problem but it happened after i detuned from the 150 to stock. when it was stock it drove bad and said doc temp high during regen after it decided to shut down. Once it decided to start i quickly went home to return to the 150 tune.
08 f250 fx4. Spartan 350 tcm. Elite studs and egr delete w/wastegate.
Superstrength08 is offline
post #10 of 11 Old 08-10-2010, 08:36 AM Thread Starter
strong_j's Avatar
Oh ok, well im currently in the process of getting the dpf delete so once i get rid of it i shouldnt have any exhuast temp too high right??
08 HD f250
strong_j is offline
