6.4 DPF DOC CAT DELETE??????? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 24 Old 08-08-2010, 08:47 PM Thread Starter
Hey guys, Im new to the 6.4 and need some help. What are the differences between a DPF delete, DPF/DOC delete, and a DPF/CAT delete? Which ones should i use to make the most power or should I delete all three?
Thanks in advance guys!
powerstr(m)oke is offline
post #2 of 24 Old 08-08-2010, 08:51 PM
08stroker250's Avatar
A DPF delete is just deleting the DPF only and leaving the DOC. A DPF/DOC is the same thing as a DPF/CAT delete. It fully removes the unit together. You have to unbolt the DPF and DOC when you just do a DPF delete because they are all one unit. I recommend doing a fully DPF/DOC delete. It's easier and you never have to worry about the DOC clogging up. A free flowing exhaust is much better anyway on a diesel.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #3 of 24 Old 08-08-2010, 08:52 PM
powerhoghp's Avatar
They are all different ways of saying the same thing. DPF is dpf. Cat is also know as DOC. Delete them all.
powerhoghp is offline
post #4 of 24 Old 08-08-2010, 08:54 PM Thread Starter
So if i go with the DPF/DOC delete, it will remove the CAT also?
post #5 of 24 Old 08-08-2010, 08:55 PM
powerhoghp's Avatar
Yes, ford refers to the CAT as a DieselOxidationCatylist.
post #6 of 24 Old 08-08-2010, 08:56 PM
DOC=CAT
DPF/CAT delete = DPF/DOC delete
Jeff Dodd
post #7 of 24 Old 08-08-2010, 08:56 PM Thread Starter
Alright awesome thanks alot guys
post #8 of 24 Old 09-01-2010, 04:45 PM
cypher0807's Avatar
Thumbs up
Just be sure to save some extra $$$ for the fine you'll get for deleting them . When I say extra I mean like 40k!
cypher0807 is offline
post #9 of 24 Old 09-01-2010, 04:52 PM
40K, why so much? I thought it was a $10,000 fine?
turbo kidd is offline
post #10 of 24 Old 09-01-2010, 05:03 PM
Huh???? 10k or 40k fine???? I havent heard anything about this. Is it a per state thing? Im really thinking about buying a 6.4L in the spring. Im in ohio, I'm the owner of a Landscaping company, all my trucks are register'd commercial and dont need e-check or anything. If i buy a 6.4L i was gonna put a straight pipe on it right away. So whats the deal???
2012 F350
ross3031 is offline
