DPF delete sensor question - Ford Powerstroke Diesel Forum
Old 07-25-2010, 01:10 PM
got a custom made delete pipe with the tree temp probes installed. what is the other sensor down there that connects with the rubber hose? a back pressure sensor or something? it is not connected on this pipe. plugged in to wiring still but not connected to pipe. will this make any difference this way with sct livewire tuner?
Old 07-26-2010, 04:28 AM
As long as the pressure sensor is plugged into the wiring harness, you are good to go.
Old 07-27-2010, 08:39 PM
ok thx there are no advantages of having it plugged in and connected to the delete pipe, rather than just plugged in wiring harness and not pipe.
Old 07-28-2010, 04:26 AM
No advantages at all.
Old 07-28-2010, 08:57 PM
Cool thanks 4 reply
