Spartan acceptable levels???
I just got my spartan tuner on. I am super happy with it.
I do have some questions about some of my readings. I am reading over 140 degrees on my fuel temp. My dashdaq is beeping at me. Should I be concerned about the level?? Also, when I get on it my coolant temp spikes up a little bit. (10-15 degrees) it will return shortly after. This ok?? Thanks alot guys |
I run the 250 tune and had my temps hit close to that range in the desert at 110* called the vendor where I got the Spartan and was told not to worry to much about that temperature until 160 so I moved the alert to 160. Don't know what the importance is of it or what to do if it gets that hot but I assume it must have some impact on something important. Don't know if it has anything to do with the tuner though.
I do know that there is a fuel cooler that coolant flows throw to keep the temps down and it sometimes fails or gets air in it. My coolant and EOT will heat up if I get on it. Think its pretty normal since you are working the engine harder. I havent had any problems in 4K miles and I have been through some serious heat driving to Vegas. |
Make sure your fuel cooler is completely full.
Where is the fuel cooler located?
Also, how close should EOT and ECT be? Mine are usually about 6-10 degrees apart? I thought I read somewhere that they should be almost the same. Also, I am not seeing any better fuel economy. I am in the 250 tune. I got 4.88's and am sitting at 2700-3000 rpm. Am I basically gonna have to go 60 miles everywhere to get good mileage? Or will it talk a few miles for the mileage to go up? Thanks alot guys. |
I am sitting at 2550 rpm at 69 miles an hour. I wonder if a gear change is in my future. Ugh.
Thanks for replies guys |
I've ben thinking 3.55's I run 4.10's now, at least 3.73 anyone want to trade gears?
where you located,i would consider this ..i have 3.73
I'd love to trade someone for some 4.30s. Idk if the 450 can use the 4.10s.
