the perfect 6.4... - Ford Powerstroke Diesel Forum
Old 07-20-2010, 04:56 PM
the perfect 6.4...
im trying to do a little research for my boss who has an 08 f-350 dually. he drives 50k plus miles a year. whats to try to improve fuel milage as much as possible, but still be able to tow and beat his buddys duramax when he wants to play while still having a reliable truck for work. what all does he need to do to his truck to make the perfect 6.4? programmer? egr? dpf? exhaust? what about head studs. does it need to be restuded like the 6.0? all advise would be greatly appreciated... like i said looking to make the perfect everday 6.4 that can work and play
Old 07-20-2010, 05:14 PM
From what I have read dpf/cat delete and a 250 tune.
Old 07-20-2010, 05:17 PM
Spartan Diesel Technologies. Check it out!
Old 07-20-2010, 05:25 PM
what brand exhaust?
Old 07-20-2010, 05:32 PM
try out the search function on this site, you can find a ton of threads about what programmers to look into as well as all other upgrades.
Old 07-20-2010, 06:59 PM
Send a message via AIM to blackcloud2k Send a message via Yahoo to blackcloud2k
I would go with a good intake, a spartan 250 tune and the dpf delete. With those three things done you will have to problem with the duramax or the reliability/driveability of the truck. When you run the 250 tune your egr will be closed so a full egr delete wont be needed. As far as the studs go, its not needed. There are many many trucks that run the 250 tune and dont have an issue. The only thing I would add to your list is a TCM especially if his truck is a job 1, but its a good upgrade for all the trucks.
Old 07-20-2010, 08:05 PM
head studs are more like insurance when you start runnig at the 250 or i havent run the hot damn tune yet just cas i dont want anything to happen but it should be fine. i have a 5" turbo back dpf delete, airaid, h&s black max, egr block off, i got 18 pulling 3 jetskis to the lake today in the mild tune, not bad compared to the 12 i was getting before, i also have a cap on the back that prolly helps a lil bit..
Old 07-20-2010, 08:12 PM
Warheads on Foreheads
H&S Performance - Diesel Performance Tuners, DPF Delete kits, EGR delete kits, and Accessories
DPFDeleteKits.com
check out H&S too, shift on the fly and tunes up to 250hp..... and their new tunes are free to download off their site whenever they release them. Everyone on here recommends Rudy's!!
Old 07-20-2010, 09:03 PM
nah..he wouldn't need the tcm until running the 310or higher tune..
Old 07-20-2010, 09:16 PM
Dually Dog
Whats TCM stand for?
