pulling tire question ??? for sled pull!!!!
Hey i am wondering if the sled pulling track is pretty hard surface. Would it be better with stock 20 inch tires or toyo 35 open country mt???? i have an 08 f350 deisel with plenty of power.
Every track is different. I have seen a lot of trucks run aggressive tread AT's with success.
I'd say less is more when you start gettin some power to the ground. Tracks vary quite a bit, and aggressive tires break stuff.
I think an A/T with a deep pattern works very well on any truck. |
not only aggressive tread breaks things but taller tires are very hard on drivelines
Run your stock 20's. MT's are just too much. If you've ever watched pulls before you'll notice that just about every truck runs either a BFG AT, Truxus STS, or similar AT tire. The less HP you have the less aggressive tire you need IMHO. Less traction off the line can translate in to more wheel speed further down when the weight hits = greater distance.
i am just worried i wont get enought traction with the stock 20 tires??? not a deep thread. So the toyo mt are too much tire for pulling on a hard track ???
Yea, I think the Toyo AT's (from experience) are good and I see a lot of guy with the Nitto Dune Grappler's on their pulling trucks.
Do you know what the track is like? Here in GA, the track is really hard. That is where stuff can get broken with an MT tire. |
ok i have either stock 20 tires which are goodyear wrangler at or toyo MT so what should i do ?
I love 'em for everything else. Pull the wranglers. |
Ive seen good success out of the procomp mt's and the Mickey baja claws but thats been on softer tracks. As stated many times above the track and terrain is the most important deciding factor on which tire to use.
