07-18-2010, 02:36 PM
Warheads on Foreheads
I copied this from here a long time ago, so you can set-up the DD to auto power off by following these instructions. Now I don't have a DD or ever tried this, just saying one of the guys wrote this up for people to use. I'm just quoting him.
You can also set up auto power off if you wish. Try this:
Auto Power Off
First, you will need to make some changes before you can proceed.
From Gauges, select "Exit".
Now select "Setup", then select "Devices". Now select "Parameters", and scroll right/left till you get to Generic OBDII.
Select "Use 6x CAN (if possible)", then select "Change". Using the keypad, type on 0 (zero), then select "Save".
From Gauges, select "Exit", then select "Setup". Now select "Power". Select the Auto Power Off time that you want to use,
and select "Ok".
The auto-off watches for a lack of OBD2 communication (indicating the the vehicle must have turned off).
So it wouldn't turn off while the engine is running, only when the vehicle is off.
