Exhaust Sound? - Ford Powerstroke Diesel Forum
Old 07-13-2010, 08:02 PM
Exhaust Sound?
Hey I recently had a dpf delete only installed. I was curious if removing or changing the stock muffler will change the sound in any way? Inside the cab it sounds like a hairdryer and from the outside it sounds decent. I just figured it may be a little bit louder with the dpf removed.
Old 07-13-2010, 08:16 PM
Removing the stock muffler will do nothing.
Old 07-13-2010, 08:17 PM
alright. thanks for the quick response. only the dpf is removed. i believe its the cat that is still there. would removing that change sound.
Old 07-13-2010, 08:18 PM
Yea, it would give you a louder and throatier exhaust note. The hair dryer sound will still be there though.
Old 07-14-2010, 04:06 AM
Im Useing str8 Pipes down pipe back and i love the sound i wish it was even louder
Old 07-14-2010, 07:42 PM
When I got mine, I ordered the 3.5" DPF/CAT delete. Kept the stock muffler and exhaust tips. Wish I would have gotten the 5" downpipe back. Currently have the 3.5" delete to 4" MBRP straight pipe with 5" tip. Will be going to the 5" downpipe back soon with a 6" tip. What brand should I go with?
Old 07-14-2010, 07:48 PM
Flo-Pro makes the only full downpipe back exhaust system. You can piece a kit together though. That is what mine will be. Powerstroker67 5" delete pipe with an MBRP 5" DPB back system.
Old 07-15-2010, 02:27 PM
AFE makes 4" DP Back kits, but not 5". If you want a nice deep tone, 5" is definitely the way to go. Cab noise is not bad at all.
Old 07-15-2010, 05:55 PM
I kinda like the sound with the stock exhaust and DPF/CAT delete. Call me crazy!
