another spartan question
what is the "EFTI" on the dash daq ?
and is there a list somewhere to show what all the abbreviations are ? |
That is the fuel rail temp. What other abreviations are you wondering about?
Thats it for now, or atleast until another one starts flashing red and beeping at me.....
Wish there was a place that would show all of the other abbreviations thanks you for the response too. |
When you got it brand new there was a paper in the box that had all or the most common abbreviaitons.
there wasnt one in mine, just the instruction booklet
Anyway to get a copy of the abbreviations ?
TFT - Transmission Fluid Temp
ECT - Engine Coolant Temp EOT - Engine Oil Temp EGRTA=EGT - Exhaust Gas Temp MGP - Manifold Gauge Pressure=Boost Pressure EFT - Engine Fuel Temp If there is anything else you are wondering about let me know. |
Fuel rail temp in the 150's, default settings sounded alarm at 140 with a high limit of 160. Is something wrong with my truck or should I bump up the alarm a few degrees? 08 6.4 ambient 85 deg, spartan 210 with dpf/cat delete stock air setup. Did notice on a fresh air filter that the resettable guage on filter was about 2/3 sucked in, stock filter must not be letting enough flow thru, I guess maybe a K&N stock replacement or a cold air kit? Any help or insight would be greatly appreciated.
S&B and AFE both make great cold air intakes. Just depends on how much $ you want to spend.
