sct performance towing
i'am new at this so i need help,installed cat,dpf delete,installed sct livewire tow tune(45hp) i would like to install performance tune(85hp) i pull two trailers one weighs 3500lbs. the other WEIGHS (8000LBS.) CAN i pull trailers safely wiyh performance tune. waiting on tunes from spartan for DASHDAQ. 120.150, and 210 tunes whice one these should i install
Last edited by julian2; 07-04-2010 at 04:22 PM. Reason: did not ask question clearly |
i have an sct tuner with tunes from SCT. i been told by mechanic i can pull light loads with the extreme tune but for loads probably greater than 4000 i better switch to tow tune to be on the safe side. so, with the Perf tune my guess is you might can tow a bit more but not the 8000 trailer. for the 8000 i would say switch to tow mode.
