H&S Mini Maxx Questions
I stripped off the DPF and Cat on Tuesday and downloaded my Mini Maxx programming and now I have some questions. I'm running a AFE Turbo-back exhaust with a stock exhaust. I did do the trans relearn for the truck too.
> Why are the shifts SO HARD going into second and third? I was running the mild tune and got fed up with the shifts so now I am using the stock tune and the shifts are much better, but still a little too firm for my liking. Is there a way to soften them? > When running the mild tune, if I give the truck a little more gas than quarter pedal, I get a lot of valve noise. It's like I can't get the truck to do an "easy" take off from a dead stop. It's like I have to go fast from a dead stop to clear up the valve noise. Is this normal? Maybe I can hear more engine noise since the exhaust is free flow? I'm like the my no DPF truck, but I'm not too impressed with the tuner. I rode in my buddies truck that has a SCT and I was much more impressed with the quality. Any help with my questions would be greatly appreciated. THANKS! |
Should have gone with Spartan. J/k With spartan there is a way to relearn your tranny so I don't know if H&S has something like that. Also how many miles have you put on your truck since the tuner?
Haha. I did the tranny relearn. I wish the process was as easy as it was on my GMC with PPE programming. All I had to do was push a button on the programmer when I changed tunes.
I've put 200 miles on the truck since adding the tuner. |
Have you added a half of quart of tranny fluid? I did that to mine and it helped out.
I didn't see adding tranny fluid anywhere in the install directions. Do you really need to do this?
I installed my mini maxx about a month ago. I did the trans relearn process twice in a row. During the first week I would occasionally get a harder than expected shift. The more I drive the truck the better the shifting. I am very happy with the way my tuner works. I have been experimenting, using the 175 tune for a tank and the 250 tune for a tank, trying to see which tune gets the best mileage.
Yes, I have a S&B air box, a 4 inch ss flo pro exhaust from the down pipe back and I down loaded the hot damn tunes from H&S. I will post my mileage after I have run thru a few tanks of gas.
For shifting try downloading another tune off the website, i like the 45 mph lockup the best, mine wont lock until about 52 which is where i want it. Also try downloading to stock and then re-downloading and do your tranny relearn in mild instead of hot. They also have some "Easy Tunes" on their website that you can try. I have noticed the longer i leave mine on a tune the better it shifts, i have also played around with acceleration and found out that you can make it shift better by going a little harder or a little slower than where you normally would accelerate |
-Casey |
