DPF sensor removal
how hard is it to remove all the dpf and cat sensors on the factory dpf to the dpf delete truck has 50k miles
spray them with penetrating lube now. The front EGT sensor is easy, the middle one is a little tight, and the back one is a PITA. The pressure sensor is easy, but be careful not to break it.
Im in just about the same boat, going to do a full turbo back exhaust install this afternoon and dont want to mess anything up. Will spraying lube help my chances of not breaking a sensor?
Lubing them up a little while before you do the job will definitely help get them out easier. Also....when you go to put the sensors back in don't tighten them down hard. Just do a good finger tighten. That way if you ever need to take them out again, it will go nice and smooth!
Good to know. I will keep that in mind because I have a feeling this will be coming off around inspection time. I am really excited to unleash this trucks power!
how much should it cost if I just buy 3 new sensors and the one pressure sensor
I believe that we can get them for you cheaper than the dealership if you want to give the office a call and get some pricing.
828-606-3263, talk with Angela or Mick |
