911 need spartan help - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-13-2010, 01:09 PM Thread Starter
tlbailes's Avatar
Hey guys,
I tried to go from the 275 TCM file to 210 TCM file and the dashdaq said download failure, reload stock. I changed to stock TCM and downloaded the recovery file Mick sent me when I updated my dashdaq. When I tried to download a tune the dashdaq says must download stock tune after download failure. I tried to call mick and left him a voicemail. I don't know what else to do. The stock file that I saved from the first time I installed the Spartan won't work, the dashdaq says invalid file. If any of you guys have any ideas please let me know, I need the truck to go back to work tomorrow.
2008 F250 CC/SB 4X4 Lariat all options except nav.
DPF/Cat delete, 4" staightpiped magnaflow exhaust, AFE intake, Spartan tuned
tlbailes is offline
post #2 of 6 Old 06-13-2010, 01:53 PM
Do you have the stock file backed up somewhere? if so try to reload the backed up version on the sd card and re-try, sounds like you stock file is corrupt. If not hold tight I sure Jeff will see this sometime soon or Mick will call you back. They are both really good about getting back to you.
rlpzzz is offline
post #3 of 6 Old 06-13-2010, 01:55 PM
powerhoghp's Avatar
You could try unhooking the batts and try reloading the tune.
powerhoghp is offline
post #4 of 6 Old 06-14-2010, 09:29 AM
cbenn's Avatar
Quoted: 3 Post(s)
More then likely Mick will need to send you a modified stock file as he did with me, when we converted over to the new flash some folks originall stock files would not work after the update, Mick sent me a new stock file and everything was good, good luck and I am sure Mick or Jeff will get in touch with you.
2017 F350 Lariat Dually
Airlift air bags W/ Wireless remote.
2.5 Icon coil springs
PMF adjustable track-bar
PMF dual steering stabilizer
cbenn is offline
post #5 of 6 Old 06-14-2010, 09:32 AM
08stroker250's Avatar
Has Mick gotten back with you yet? I won't be able to help you out with this issue unfortunately. Mick will have to send you a recovery file.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #6 of 6 Old 06-14-2010, 10:04 AM
mick1955's Avatar
He has to have a new stock file. A recovery file will not allow him to return the truck after a download failure. Hopefully his new stock file will be here this afternoon or tomorrow.
08 F350, King Ranch, Dually, CC, LB, White/Gold, 4x4, 4.10, Auto, Spartan Phalanx Flash Console, 310 tune, AFE Stage II Air Intake PG-7 w/Torque Tube, Code Alarm, & Console Vault
08 F350 King Ranch, SRW, CC, LB, White/Gold, 4x2, 3.73, Auto, Spartan Flash Console, 310 Tune, S&B Air Intake, Code Alarm, & Console Vault
USAF Retired - Support our Troops
DD Help File
mick1955 is offline
