H S tuners come in... - Ford Powerstroke Diesel Forum
Old 06-09-2010, 07:59 AM
Question H S tuners come in...
Guys I will be towing 8k lbs from NC to WA state in the next couple of days and would like to know what tune you guys recommend. I will have the black maxx with the H S cat/dpf delete and the stock intake. I want to run a tune as safe as possible for towing.
Old 06-09-2010, 08:04 AM
8lbs you could use a escort and get better mpg =P
Old 06-09-2010, 08:19 AM
I don't know nuttin....
Yes, with 8 lbs i think you should ride your bike instead of driving...
Old 06-09-2010, 08:20 AM
I don't think you can run a stock intake with a tune and dpf/doc delete.
Old 06-09-2010, 08:34 AM
Its not a good idea at all to run any performance tune with a 8k lb load.
Unless its a tow tune which isn't available with H&S yet.
Old 06-09-2010, 08:41 AM
You can run the mild tune and be fine aslong as you keep an eye on trans slip and egts..
Old 06-09-2010, 09:27 AM
Are you sure about that? Anyone else?
Old 06-09-2010, 09:50 AM
Well I just ordered a S&B intake and it will be here tomorrow, thanks to Aaron at DPF deletes.
Old 06-09-2010, 07:54 PM
Well I got the HS performance tuner and the cat/dpf delete installed and all I can say is wow! Got a few questions though:
What egt temperatures are dangerous when towing? I think I saw 850 today.
Why is my pyro 2 stuck in 622? It seems as it is turned off.
Defueling? Do I leave that alone? What does that do?
When I run "no power" does the tranny run with the stock tune? I was recommended to tow with the lowest level....no power? Or did they mean mild?
Old 06-09-2010, 08:06 PM
I towed that much with mine to Cali and back and it was fine on Wild. Just watch ur guages. I never saw above 1100 running like that.
