where can I get 2" long u bolts
I have 2" blocks off my old f250 that I want to add to the rear of my f350. Where can I get 2" longer u bolts for them? Thanks
Off road shop maybe? Not 100% sure. I also didn't know you could stack blocks either. Sounds a little dangerous to me, but I also don't know much about that type of stuff.
Never stack blocks..U bolts are easy to get also the proper lift blocks.
Ok so I should just look for 6 inch rear blocks then instead of stacking mine.
Yes, exactly.
Ok thanks for the help, I'm glad I asked on here before I did it without checking. Thanks
I had an 03 SD that I couldn't find 6" blocks and the shop told me to just stack the 4" and the 2". He even gave me new u bolts to do it for free. I never had a problem but later I was told it was not a good idea. My 2010 I got Icon's 6" 1 piece lift block and it is a much better piece than stacking
I got stacked blocks in back and was told as long as im not pulling a lot they be fine. also check out rocky mountain susp for u bolts 30 something a set and there drop shipped from tough country in Tennessee i believe
Thats cause the idiot that told you that just wanted a sale.
Other option is using Deaver rear mini spring packs..2.5" and the stock block..much better ride quality and less axle wrap..got them on mine. |
