pressure sensor fitting - Ford Powerstroke Diesel Forum
Old 06-04-2010, 02:18 PM
Is there anywhere I can go to get a pressure sensor fitting asap or is there anything else that would work? Thanks
Old 06-06-2010, 10:24 AM
You can use a male quick connect fitting off of your air compressor. You can also use a plug or barb fitting that will work.
Old 06-06-2010, 10:28 AM
Ok thanks, I found a brass air line fitting I had w the barb on it that fit but my fitting from cobbs is supposed to be here tuesday so I might as well just wait now. Thanks
