pro's and con's of blank-off plates - Ford Powerstroke Diesel Forum
Old 06-04-2010, 09:37 AM
I'm thinking about putting EGR blank-off plates on my 6.4 is there anything i need to be worried about when doing this as far as it hurting my truck. I already order a SCT and down pipe back exhaust.
Old 06-04-2010, 09:44 AM
Higher back pressure
Old 06-04-2010, 10:06 AM
I have been reading and i dont no if i understand this right will the SCT programmer keep it closed on some programs. "EGR"
Old 06-04-2010, 11:31 AM
You can shut off the EGR with the tuner
Old 06-04-2010, 11:40 AM
08stroker so if you put the blank off plates in we should install some sort of waste gate or is the plates a waste of money and go with a full delete with waste gate.
Old 06-04-2010, 11:41 AM
Full delete with wastegate
Old 06-04-2010, 02:54 PM
what would the consequences be of running it with the EGR cut off. "cut off by the programmer"
Old 06-04-2010, 04:10 PM
Warheads on Foreheads
most tunes and most high hp tunes turn off the egr under throttle anyways, the valve then functions normally at idle only
Old 06-04-2010, 05:48 PM
It just increases back pressure, but not to the point of being destructive.
Old 06-05-2010, 03:33 AM
thanks for all the info guys..
