puked
i was runnin with a buddy of mines duramax today and after blowing by him he called me an said he saw some white smoke coming from out the front of my truck. i pulled over to see that my truck puked. how do i know if i need to change the head gaskets and what not
how much colont should i have in the container thing
It's not as common for a 6.4 to puke as it is a 6.0. What JOB is the truck?Have you had the radiator replaced?
If you run the 310 hard, you may lift the heads. If you pressure test the system you can rule out radiator, degas bottle, and cap.
im not certain but i think its a job 1 and i have recently replaced my radiator.
i drove the truck after this happened and it every thing seems to be normal |
Were you running the 310? Do you have the short air dam in front? You can tell if it is a Job 1 for sure by your build date.
If they just replaced the radiator the degas bottle may have been over filled also.
Like everyone else asked, what tune are you running? |
It is probably your head gasket if you have coolant all under the driver side of your hood. Mine puked like crazy on only the 250 tune.
i had the 310 tune in an i had the short airdam. the truck is running fine today and all my temps are normal
I am going to go ahead and say that you probably lifted the head since its a Job 1 truck.
