Stacks? - Ford Powerstroke Diesel Forum
Old 05-08-2010, 04:20 PM
Stacks?
Who are you ordering from? Also are they from the DPF then wrap around so I can reinstall the DPF when I goto the dealer or what?
Old 05-09-2010, 01:38 PM
Just check some of the vendors out on here. I recommend going with MBRP's stack kit. Yes, it will hook up to the DPF if you have the reducer for it.
Old 05-27-2010, 09:16 PM
i am buying the spartan cat/dpf delete kit today and iam running a single 7" stack offset and i found all parts needed (5" elbow, 5" flex and clamps") at Elliotts Auto (big rig dealership and repair shop) in MD so just check your local dealerships and see what they have laying around. hope this helps
Old 05-28-2010, 04:20 AM
Send a message via AIM to eric.davis
I have a MBRP DPF back dual stack with 6" mitres. It is squeaking now. and I have taken it all apart and back together a couple times and it still moves around.
