blown head gasket...need advice
I was towing 10,000 pounds on the spartan 275 the truck practically puked out the whole coolant tank. So heres the thing I'm pulling the cab and putting in elite studs but is there anything else that should be done while I have it off? I'm lookin at doing the elite high pressure fuel pump, but here my concern if I ever have to take the truck back to stock for emissions or a visit to the dealer will it even run? Im lookin for high 11's on Nitrous. thanks for the advise
I have been wondering about that situation also. From what I have read it isn't a problem. The system will provide only the fuel that the stock one requires not over fueling it.
The HPFP from Elite will work on stock tuning.
ok that is good news!!! do I have any other options as far as pumps go?? Im also looking to do some of elites injectors and a wastegate any advice there? will the elite pump support there 110hp injectors?
The pump will work with the 110 injectors, but you can want to contact Spartan about getting the tunes tweaked.
will the truck run "ok" for a few days after I install the pump and injectors? cause im gonna need it cause its my DD. is there any special tools required for puting the nozzles on??
bump
Not really any special tools, but if you're not very carefull, you can render the injectors useless.
