Intake Question - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-05-2010, 05:39 PM Thread Starter
Intake Question
I have a 2010 F-250 and was looking at the S&B system and then the AFE stage 2 PROG7 system. What I am wondering is which flows better and is there any pros to have the fully closed system that S&B has. Any replies would be greatly appreciated, thanks.
ford82183 is offline
post #2 of 6 Old 05-05-2010, 05:58 PM
08stroker250's Avatar
Really the main thing with the S&B is it is difficult to clean. You have to basically take everything back apart to get to fliter. The AFE on the other hand, you just take the cap off the filter box and removed the filter to clean it. They both flow well enough for anyones needs. Just a matter of dealing with the PIA cleaning process of the S&B.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #3 of 6 Old 05-05-2010, 06:40 PM
Feedback Score: -1 reviews
Couldn't have said it any better!
2009 LARIAT 4x4 PSD
[Upgrades]
-2.5"King Coilovers & Bypass system
-Deaver Full leaf kit
-Kumho Kl71 37x13.5x20
-310 Spartan Tune & TCM
-5" Flo Pro Dpf / Cat Delete
-Spearco Intercooler
-AFE Intake & Pro-Guard 7
-Twin Viair 480C On Board Air System
-Nathan K5LA Running @ 200 Psi
-55 Watt HID & Fog
-Titan 51 Gallon Fuel Tank
2005josh2006 is offline
post #4 of 6 Old 05-05-2010, 06:44 PM
Raul@Stealth Automotive's Avatar
very well said.. if you can afford it def go with the AFE unit... if you pm me which one you want i can send you over a killer deal
-Raul
Raul@Stealth Automotive is offline
post #5 of 6 Old 05-05-2010, 07:13 PM Thread Starter
Thanks for the info, I will pm when I get some money together. Thanks again for the responses.
post #6 of 6 Old 05-05-2010, 08:36 PM
Erikclaw's Avatar
-Raul
I would be interested in that too if you would be so kind. I bought the Volant and hate it. You can't clean the (100,000 mile) filter and it causes the vacume sensor thingy on the housing to get sucked in and have to reset. Was looking at the AFE, looks like a tight, flowing design.
2008 King Ranch 6.4L CC Elite LP & HP fuel systems, II pump, tow compounds, stage 2 ported heads, stage one cam, tow compounds, ported intake and manifolds, egr delete/wastegate, 60hp injectors, full Elite trans
Erikclaw is offline
