6.4l engine build?
hope i posted this in the right place. Im looking to really build up my 08 and take the dpf off, i would like to know if people would be willing to share there experiences and what they are running and how it is going for them. any help or posts would be appreciated by me and im sure others have wondered the same thing.
are you looking to build it or just take the dpf off and just tune it?
Powerstroker67's got a good write-up on doing the delete. It's stickied in this forum. Also, I've got a thread with pics of my delete here:
My Delete (with pics)
mdavis, yes i did see your write up and it helped alot, i am looking just to tune it and remove dpf and cat, i currently have airintake. But ive heard that the ford has problems with the injectors and i dont want to go try and add to much power and not do something i need to and blow a gasket or anything.
I recommend the Spartan tuner, a downpipe back exhaust, and an intake for starters. What else are you wanting to do?
Well, I guess the next step would be to pick which tuner you want to run. I picked Spartan because it's supposed to be less visible to Ford if you have to take it in for warranty work. Plus, I think the dashdaq is awesome. Other people choose other tuners for various reasons. If you do a quick search, you'll find countless threads arguing over which is the best. And if you're not careful, that's what this thread will turn into.
But from my own personal experience, I run the Spartan 210 tune. After talking extensively with a Spartan tech, who was using Spartan even before he was one of their techs, I decided on it. After a few tanks, I may try the 250 tune to see what the difference in MPG's is. From what I've gathered, if you've done your intake, your head bolts should be good for anything up to the Spartan 250 tune. For some of the higher tunes, you may consider a head bolt upgrade. Like you, adding a ton of power wasn't my main priority, but the higher tunes tend to get the best MPG's, ironically. |
Dangit, Jeff. You hit submit about a millisecond before I did.
![]() Out of curiosity, why do you recommend a full downpipe back over just the delete pipe? |
Welcome. As stated we try to be careful and not start any wars here. There are alot of Spartan guys in here and they have been around a while. I went sct livewire with a custome tunefrom river city diesel and absotuly love it, but I also got a steal on the tuner!! If I had to do it with all new parts I would go h&s mini maxx for 3 reasons
1. Free tunes whenever they come out with new ones. Thant mean new toys for free 2. Dpf delete pipe does not need the sensors. That means easy swap! 3. Shift on the fly. That means even if u were on a soft tune you could quickly change to kill that pesky ricer!! Just my 2 cents. |
yeah, thanks that helps alot, i think im going to try something just like you have, seems pretty safe while getting the job done and then i can build from there. and jeff i also thank you for your responses i really just want to get the best potential out of my truck without upgrading alot but with the smallest amount of risk. And davis i know what you mean, i am very familiar with gm tuning and it is the same way with the tuning and the power, i just walked into a ford a little while back and am not familiar with them nearly as much as i am with gm, but thanks to you all i am getting to know enough.
