my 2009 f250 gas gauge = POS - Ford Powerstroke Diesel Forum
post #1 of 26 Old 05-03-2010, 03:26 PM Thread Starter
what is wrong with ford? This is the second time I have ran out of gas . First time the mpg thing said 60 till empty no warnings or nothing.
This time showed 105 miles till empty ran out of gas again !
Worst part is the thing wont FUC**NG start when you put more diesel in it ! Do i have to call the dealer again and pay these idiots for a problem that is caused by this truck ?
I know its not just mine,. my buddies does this too, can you not go under half a tank without concern to run out of gas and not be able to start it again?
09 f250 fx4 6 inch pro comp lift with 20 inch monsters on 37 nitto grapplers... Spartan 250 Daily
05 corvette, 402 stroker,afr heads, texas giant cam, fast 92, corsa cans, z06 widebody/brakes, Built rear end, lg headers, 650hp... weekender
2009 kawasaki ultra 250 supercharged jet skis. Lake
cmn130 is offline
post #2 of 26 Old 05-03-2010, 03:59 PM
AED F250's Avatar
I have had this happen as well. It will eventually start once you get fuel in it. My truck took about an hour of trying before it fired.
2008 FX4
Fabtech 8 w/37's
Intake, delete pipe/exhaust, Spartan/KEM tuning
567 RWHP/1128 RWTQ
13.3 @ 103.9 MPH
AED F250 is offline
post #3 of 26 Old 05-03-2010, 04:01 PM Thread Starter
thats just nuts. what a piece of junk.. iv never had this problem with the dodges, and chevy diesels i have owned. i have cranked it so meny times nothing, and ford wont warranty it due to "not being covered..." there famous words .
cmn130 is offline
post #4 of 26 Old 05-03-2010, 04:08 PM
AED F250's Avatar
What seemed to get mine to start was priming the pump by cycling the key over and over. Then while cranking the truck over holding the gas peddle at about 1/4 throttle. This is also the procedure I used after having the cab off the truck and the entire fuel system drained.
Hope this helps! Good luck.
2008 FX4
Fabtech 8 w/37's
567 RWHP/1128 RWTQ
13.3 @ 103.9 MPH
AED F250 is offline
post #5 of 26 Old 05-03-2010, 04:09 PM Thread Starter
ill keep trying im sure the bat will die soon though. there should be a better way specially since this is a common problem with these things.. thanks for the help.
cmn130 is offline
post #6 of 26 Old 05-03-2010, 04:21 PM Thread Starter
sputtered a few times then died. now i cant get it to sputter anymore. is this for real? does ford really expect normal people to tolerate this?
cmn130 is offline
post #7 of 26 Old 05-03-2010, 04:31 PM
Ford fuel gauges suck. My sisters 07 was out of fuel under a half tank. Take it in under warranty.
2005F250 is offline
post #8 of 26 Old 05-03-2010, 04:47 PM
08stroker250's Avatar
Never go by what the dash says......
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #9 of 26 Old 05-03-2010, 04:48 PM
Ive had mine down to 25 miles until empty and never ran out of FUEL or DIESEL.
F250 reg cab short bed
JMart is offline
post #10 of 26 Old 05-03-2010, 05:01 PM
jrod80's Avatar
That's strange man...that sucks. I've been down to 15 miles till empty and never ran out.
**Sold** 2008 F350 PSD CC SB Lariat - 8" Fabtech Radius Arm kit, OUO Traction Blocks, Icon Remote Res shocks, Icon dual stabilizer, 20" BMFs on 38x15.5 Toyo MTs, Spartan 275, S&B CAI, Flo-Pro exhaust, RBP Grille, N-Fab steps, CRE Rocker Flares, Recon mirror and tails, projectors with 6K HID, Alpine IVA-W505 DVD with Sirius and cam, Alpine 5x7s, Fosgate amp and 10" sub
jrod80 is offline
