Has Ford Not Heard of Never-Seize? - Ford Powerstroke Diesel Forum
Old 04-28-2010, 05:04 PM
Planning to do my DPF-delete this weekend. In preparation, for about the last week or so I've sprayed all three temp probes with Liquid Wrench almost every afternoon after the exhaust has cooled off. This evening, just as a test, I grabbed my trusty 13mm Kobalt wrench and rolled the creeper under there to yank on the one behind the DPF. #@$%, that thing is in there tight! I didn't put all my weight behind it (because I need a ride to work tomorrow), but I pulled on it pretty good. It didn't even budge.
I'm thinking it might be easier just to unplug the sensors, drop the cat/dpf spool, and get them out when I'm not laying down on a creeper. But, I'm worried that I might break one of them and be up a certain creek without a paddle. I'd prefer to at least get them to move a little before pulling the spool out.
Any tips from you pros that've done this before?
Old 04-28-2010, 05:06 PM
shaking things up
pb blaster works the best it creeps better than the rest
Old 04-28-2010, 05:12 PM
your right ,unplug the sensors and remove everything,then soak again and you should be ok,wasnt bad for me at all,this way
Old 04-28-2010, 05:15 PM
Feedback Score: 7 reviews
Send a message via AIM to dereku
x2 PB is awesome
Old 04-28-2010, 05:25 PM
I saw that stuff right next to the liquid wrench. Guess I picked the wrong one. I'll grab some tomorrow and put some on it tomorrow night, Friday night, then Saturday after I drop the exhaust. I'll let it soak an hour then give it another shot.
Old 04-28-2010, 05:30 PM
Send a message via AIM to jhaddox
unplug all of the sensors, drop the exhaust to the ground..its way easier that way...i got 2 of mine off after i took the exhaust off...i still had to use heat and vice grips on one of them to break it free...
-PB Blaster is your best friend
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
"Don't bust your knuckles, bust your nuts" with PB blaster.
Old 04-28-2010, 05:39 PM
Using heat makes me a little nervous. I've read a lot on here not to use heat on them.
Old 04-28-2010, 05:40 PM
Yeah, PB Blaster is great, or if you can find it, Kroil (quite a bit more expensive though and hard to find)
Old 04-28-2010, 05:52 PM
Hell, I'd pay $20/can if I knew it'd get those sensors loose without breaking them.
