Help!! Truck broke down - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-25-2010, 02:55 PM Thread Starter
Blk350on20s's Avatar
My DD was driving my truck not beating on it or anything and we hit a hill and the truck started to shutter. Looked back and there was whiteish gray smoke. Pulled over and shut it down. Temps were fine. It smelled like burnt oil. When we pulled it up the ramp onto the trailer some oil was dripping out of the exhaust. Im thinking turbos. I pulled the intake off and the one compressor wheel was fine but thats all I could see. Ive snapped shafts on my turbo in my 6.0L and it did the same thing but I dont think it had the shutter. What do you guys think? Anything else you guys can think of? Thanks Ryan. Sorry for the length.
08 F350 4x4 CCSB 6.4, 6" on 37s and 22s, Spartan DD w/ 310/KEM 345, Elite HPFP, Ported rails, EGR delete w/ wastegate, studs, CFM +, Rudys IC pipe, BD BOV, FASS 150 w/ custom fuel system, S&B intake, Rudys downpipe and DOC/DPF delete, CCV mod, Zex nitrous, Suncoast Trans, 1 piece drive shaft, Recon and tint everywhere. Under Construction
Blk350on20s is offline
post #2 of 6 Old 04-25-2010, 03:51 PM
08stroker250's Avatar
When I had white smoke and oil come out of my exhaust, it was a fuel injector that hung open, filled the crank case with fuel, and my truck ran away. Not saying this is the case here, but it definitely could be injector related. I would be surprised if one of the turbo's is bad, but it very well could be.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #3 of 6 Old 04-25-2010, 04:33 PM
greasltn's Avatar
When you pulled the intake off, was it full of oil? If your crankcase gets overfull it fills the intake tube from the CCV. Check your oil level, and see if your turbo actuator moves. I've only seen one turbo act up on the 6.4. If you have the BOV set up right you don't have to worry about the turbo shaft.
-John
Rudy's Diesel Performance - 919-383-9300 - Diesel Tech
greasltn is offline
post #4 of 6 Old 04-25-2010, 06:15 PM Thread Starter
Why would it put oil into my exhaust if it was an injector?
No oil in the intake tube other than what the ccv normally puts out. I will have to take it apart in the morning when I get back up north. Would the actuator not moving screw something up?
post #5 of 6 Old 04-25-2010, 06:56 PM
Answer below.
Jeff Dodd
post #6 of 6 Old 04-25-2010, 07:06 PM Thread Starter
oh alright. Well that wasnt full so I guess theres some hope that its not the injector.
