SCT 9621OR - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-21-2010, 09:02 AM Thread Starter
Question SCT 9621OR
2008 cc 6.4 3" lift 35's
looking at removing the DPF not looking for huge horsepower just want that dang filter removed. anyone tried this or the 9625OR how do you like it. please dont turn this into a boxing match im not looking at the most power just DPF removal.
thanks in advance.
jeffvest06 is offline
post #2 of 8 Old 04-21-2010, 09:05 AM
Raul@Stealth Automotive's Avatar
what about something like this: 2008-2010 Ford 6.4L XRT Race Tuner
Raul@Stealth Automotive is offline
post #3 of 8 Old 04-21-2010, 09:08 AM Thread Starter
i would need external monitoring correct?
i know the sct doesn't look the greatest but it still contains the gauges
post #4 of 8 Old 04-21-2010, 09:19 AM
Yes, the XRT is for downloading updates, uploading the tunes then either unplugging and safe storing or leaving plugged and selecting different tunes on the fly.
Vettester is offline
post #5 of 8 Old 04-21-2010, 09:20 AM
TripleE44's Avatar
Casey from H&S says that they tunes are designed not to need an external gauge. Sounds like the XRT may be your best bet. Although, the new Mini Maxx is supposed to come out soon, which will have Trans Tuning which the XRT does not have.
I've got the SCT 9625OR right now, and I'm looking at the Mini Maxx as a replacement. Not for power, but just because SCT has left a bad taste in my mouth. It will have the same tunes as the H&S Black Maxx which includes a couple low power settings and some high.
Just something to consider....
TripleE44 is offline
post #6 of 8 Old 04-21-2010, 09:34 AM Thread Starter
if you dont mind me asking what kind of bad taste is there something wrong with the sct
post #7 of 8 Old 04-21-2010, 09:46 AM
TripleE44's Avatar
Customer service. That is why I'm going to switch over to the H&S, because Casey seems to be lightyears ahead of them with customer service aspect alone.If you do go with the SCT, you'd be really better off getting something from Innovative, Eric seems to be a good guy. I don't want to get a poo flinging contest going on, so I'll leave it at that.
Not to mention, I've heard good things, and I don't want to necessarily spend the $$ for the Spartan or Black Maxx so the Mini Maxx is in my good range.
post #8 of 8 Old 04-22-2010, 01:29 PM
wontonrunner's Avatar
I have the 9625OR and other than the screen needing replacing I have had little issues. Matt from SCT has been great with me!! Something glitched on my truck and i was stuck with half stock tuning and half RCD tuning and i was locked out. I contacted SCT and within a couple days they had a rebuild file and re-wrote my TCM.
I rarely ever monitor my temps or anything. The RCD and most other tunes on the SCT dont get hot enough to really have any concerns over from what guys have been finding.
My Little Truck
2008 F350 FX4 Superduty Fully Loaded
6" Frankenstein Lift
20" Jessie James Rims
35" Toyo MT
Chrome Steps and Box Rails
Jackrabbit Sliding Bedcover
Eclipse Navigation/DVD with Rear TV's
SCT9625OR , Powerstroker67 DPF/DOC and 4" MBRP
My Big Truck
1991 Toyota 4runner
Solid Axle Swap
19" over Stock using F150 leaf springs
D60 Front 14BFF Rear
Detroit Locker up front, Mini Spool in the rear
39.5" TSL on Custom Hummer Beadlocks
Custom Baha Fenders
wontonrunner is offline
