Squealing coming from turbo. - Ford Powerstroke Diesel Forum
Old 04-16-2010, 06:02 AM
Has anyone had a squealing noise coming from the turbo. It started a few weeks ago and now is there all the time. Its there at idle and gets louder then goes away when the engine is under load. I installed a exhaust and spartian tuner about 3000 miles ago. Just hate to go back to stock if its a easy fix. Kinda sounds like a air leak but dont know. Also there is smoke coming from the back of the engine when you give it gas. Thanks.
Old 04-16-2010, 07:36 AM
You have an exhaust leak most likely. Could be the turbo up pipes leaking. How many miles are on your truck?
Old 04-16-2010, 12:03 PM
Well there is your problem! You can't put gas through a diesel..... But seriously it does sound like you have an up-pipe, or EGR pipe leak. Jeff sounds to be on the right track. Also could be a downpipe leak, but they usually wont "squeal" like the pre-turbo pipes.
