throttle Plate removal - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-28-2010, 06:58 PM Thread Starter
Ok I did the egr delete on my 6.4 and along with the delete did the new cfm intake from elite that uses the 6.0 cfm elbow. I have the tunes from spartan that are egr delete compliant but still have codes has anyone ever done the throttle plate delete from the stock Cfm elbow. If any one has did you get codes, im really stumpd on what to do cause i dont want to take the new cfm off and us stock hardware.
Moyerboy is offline
post #2 of 12 Old 03-28-2010, 09:06 PM
throttle plate removal
I believe you must leave cruise and or egr delete sensors in the system or do what i did and use the dirty diesel elbow which has a flange on each end that bolts to the engine and cruise control. I do not know if you can go completely without egr sensor.
Aaron at rudys should know.
Good luck
promodracer is offline
post #3 of 12 Old 03-28-2010, 09:25 PM Thread Starter
Good luck
i tried getting the elbow off of dirty diesel but he told me 450 for the part and until i get heads and studs im brock for that is getting my money right now. im still lost on how i need one of the sensors plugged in when ive seen pics f the mod beng done to other trucks
Moyerboy is offline
post #4 of 12 Old 12-17-2010, 07:45 PM
little off subject but what purpose does the throttle plate serve? Is it a safety feature keep the engine from run away? Used for engine breaking in tow mode? Doesn't fuel flow control the RPMs?
joey011582 is offline
post #5 of 12 Old 12-17-2010, 08:12 PM
08stroker250's Avatar
My truck still had the throttle plate when it ran away, so definitely not that lol
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #6 of 12 Old 01-16-2011, 09:15 PM
I know this thread is about a month old but came accross it and thought i would chime in. the throttle valvle plate is striclty part of the emissions crap. It regulates fresh incoming air to allow the "proper" amount of Exhaust gasses to be drawn in and recirculated. In a nut shell it closes to limit fresh air in so the Exhaust can be reintroduced into the intake.
rbmedic75 is offline
post #7 of 12 Old 01-17-2011, 04:35 AM
eric.davis's Avatar
Send a message via AIM to eric.davis
I'm curious too because I have no cruise but I'm also getting P0193 code. What are you getting.
2011 Dodge 2500 6.7 CCSB SLT
'08 F-250 with some stuff done
545/1050 on #2 SOLD
eric.davis is offline
post #8 of 12 Old 01-18-2011, 07:17 PM Thread Starter
i just tyed mine up on the second alternator bracket after i did the egr delete so I have no codes and got my tunes redone by mick and matt at spartan all is good now.
Moyerboy is offline
post #9 of 12 Old 01-20-2011, 03:05 AM
hopperwagonbob's Avatar
I did dirty diesels elbow.(285 shipped I think) when I did my egr delete a month ago. And just left 3 connectors unhooked off the butterfly/egr valve elbow.then bought the 275/300/310 for the egr delete from mic at Spartan. I asked him about the cruise and he said it would still work. But the roads are crap and haven't drove it much to try it. And no codes yet. Except the rear axle ratio code 1635 I think?
hopperwagonbob is offline
post #10 of 12 Old 01-20-2011, 06:46 PM Thread Starter
if i unplug my throttle plate i get a wrench and then my cruise doesnt work i have tried to get it fixed but gave up. it doesnt help my truck is a manual so its hard for them cause i am like the only manual guy with spartans big tunes
Moyerboy is offline
