exhaust - Ford Powerstroke Diesel Forum
Old 02-15-2010, 05:01 PM
exhaust
where can i purchase a full 4" or 5" full turbo back exhaust from?
Im currently running spartan with 3.5 cat/dpf delete and wanting to upgrade the system.
Old 02-15-2010, 05:10 PM
No one makes a full TBE yet. You will have to get a Flo-Pro,Elite or Powerstroker67 down pipe and then a 4" or 5" down pipe back exhaust. James at Rollin Smoke Diesel can hook you up. Later.
Old 02-15-2010, 05:19 PM
does the 4" dp have a big advantage over stock??
Old 02-15-2010, 05:28 PM
You can get a 4" Flo-Pro downpipe with a 4" or 5" Flo-Pro exhaust. That would technically be a turbo back exhaust. Let me know if I can help ya out!
Old 02-15-2010, 05:49 PM
We have the Flo Pro kits ready to rock Rollin Smoke Diesel. DPF Delete Exhaust, 219-851-1195
James
RSD
Old 02-15-2010, 05:52 PM
Dually Dog
Check out the AFE I just installed mine and love it. if your not over 500hp a 4" will give you the most power.
Old 02-15-2010, 08:04 PM
does 4" give you much more power increase over the 3.5" stock?
Old 02-15-2010, 08:13 PM
4" will give you a throatier exhaust note, better air flow for cooler EGT's, but no real power increase.
Old 02-16-2010, 04:06 AM
It also helps spool up a bit faster.
Old 02-16-2010, 05:20 AM
any 4 or 5" dpf back exhaust will bolt up to my 3.5" cat/dpf delete??
