Fuel Mileage Drop? - Ford Powerstroke Diesel Forum
Old 02-12-2010, 07:07 PM
Angry Fuel Mileage Drop?
It's been way down since the HG install. Could the winter blend cause a 100 mile loss a tank? Seems extreme.
I have no signs of a leak. The oil doesnt smell of fuel. I havent seen any spots in the driveway or anything.
The fuel filers are 8K old and are getting replaced this weekend.
Thoughts?
Old 02-12-2010, 07:08 PM
It's been cold, have you been letting it idle a lot?
Old 02-12-2010, 07:10 PM
No excessive idling...
Did your set it back to stock and then reload the tune after the HG's? Some times it takes a while for the tune to settle back in. I had the same issue last time I changed tunes and it was right around 100 miles per tank loss.
Old 02-12-2010, 07:11 PM
I've gone through several tanks of fuel since then. I've played around with several tunes too.
Old 02-12-2010, 07:12 PM
IDK maybe just let it run through a couple tanks. If it keeps up you might just have yourself a problem
Old 02-12-2010, 07:13 PM
Nevermind your a little quicker on the draw then me.
Old 02-12-2010, 07:15 PM
It takes a couple of tanks, and your having to start all over again everytime you change the tune. Its very annoying and I dont know why it takes so long to relearn but it does.
I mean, it doesn't seem out of this world to believe that the Winter Blend could cause 3mpg drop but I would have thought it would have happened a little quicker than Jan.
Old 02-12-2010, 07:22 PM
It could be the fuel but I didnt notice that big of a drop with winter fuel only when I changed tunes.
