back to start truck wont start? - Ford Powerstroke Diesel Forum
Old 02-11-2010, 04:24 PM
hay guys im in a little trouble here i traded the truck in today but had to run home to put the dpf back on and return to stock first i put the dpf back on and returned it to stock and fired it up for 30 sec or so after it was back to stock. left it alone to finish the install and now it wont start codes are p1000 system ready and a exhaust sensor 3
ive tryed disconecting the batts.
thanks guys
matt
7802106288
Old 02-11-2010, 04:35 PM
one of the sensors isn't all the way in. try to clear the codes with the DD and try again. If not contact Mick.
Old 02-11-2010, 04:54 PM
Its a problem with a EGT sensor, check those connections.
Old 02-11-2010, 05:45 PM
You will have to use a screwdriver and jump across the starter solenoid. The EGT sensors will not allow the truck to start besides jumping across the solenoid. Just make sure they are all plugged in before you try it.
Old 02-11-2010, 06:22 PM
Correct the problem with the sensor first. Next reload the stock file if you don't want to jump it off the starter.
Old 02-11-2010, 07:04 PM
This is your trucks way of saying it doesn't want to go!!!!
Old 02-12-2010, 12:27 AM
You can also pull the starter relay and jump it at where the relay plugs in under the hood. Saves on laying on your back in the snow/ice or rain.
Old 02-12-2010, 08:11 AM
There is a jump wire dedicated to this exact purpose by the battery on the passenger side. I will see if I can pull up the schematic on wire color.
Casey
Old 02-12-2010, 08:24 AM
I got a p1000 code once does anyone know it means? I looked it up but not sure what it means.
Old 02-12-2010, 08:31 AM
P1000 OBD Systems Readiness Test Not Complete - This error occurs when all other DTC’s have been erased from the system. This error will subside when all OBD monitors have been completed.
