Drag Radials??? - Ford Powerstroke Diesel Forum
Old 02-10-2010, 06:08 PM
Drag Radials???
I'm looking to get some drag radial to put on my stock 18'' rims. I'm looking to get either the Yokahama's or the Perelli's and the sizes vary a bit that largest of the Pzero's are 335/30R18 and the Yokahama's are 315/30R18. They both seem to be decent tires but can someone give me a thorough explanation of what those sizing numbers mean and whether they will fit on my stock rims.
thanks!
Old 02-10-2010, 06:10 PM
What gear ratio is your truck? Also, are you going to be running in the 1/8th or the 1/4 mile?
Old 02-10-2010, 10:03 PM
thanks!
Pzeros or yoks thoes are not drag radials thoes are high performance street tires if you want DRs I like mickey thompson.
If you are going street tire then nothing beats the P-zero. (it has to be just P-zero, no other names after that) I will warn you thet cost alot of cash and will wear very fast.
Old 02-10-2010, 10:21 PM
Hmmm... they were both listed as drag radials..Im kinda going toward the yoks because they dont have near the cost of the P-zeros. Im going to be running both 1/8 and 1/4 passes with these..I will look into those Mickey T's. The truck is a 3:73.
Old 02-11-2010, 10:05 AM
You will need a decent size tire to be effective in the 1/4 mile, like a 33" atleast. Why not just get some Toyo Proxes? That is what Rudy runs on his drag truck....they seem to be working pretty well. They are also VERY cheap.
Old 02-11-2010, 10:32 AM
Nope P-zero is a low profile high performance street tire.
A DR needs side wall to flex on your launch so you dont have tire spin. check the MT website I am sure you can find somewhere on there may other reasons. Now you cant drive with a real DR on the street you cant take corners and stuff. so if you want a true track only DR MTs are the way to go.
Old 02-11-2010, 01:54 PM
I run 315/35/18 Toyo TQ Drag Radials on my Procharged Z06. They are STICKY! Just say'n!
Old 02-11-2010, 02:15 PM
Beautiful car!! that thing looks sick! and i'm not a corvette guy at all...
But how does that beast handle speed bumps, LOL
Old 02-11-2010, 03:12 PM
Here's my L on 305/45-18 drs (11.5" rim)
