NEED advise. Headstuds?
I'm running the spartan 275, afe intake, and 4 inch dpf delete pipe. my truck is going in the shop for a blown headgasket. Will studs prevent this from happening again? just want to know the advantages. will there be enough clamping force to prevent another gasket failure? Any information on this will be greatly appreciated. Thanks
Do you plan on just running the 275 always, or will you will be going up to the 310? It should be fine, but drive pressure is really high with those tunes. John has put a lot of miles on his truck with studs and no wastegate with no isses.....a lot HARD miles.
Well i might run the 310 sometime. I just dont want this to happen again. would headstuds be a good investment or should i just get it warrantied with factory bolts? Anything else recomended?
Dont have the funds for it now. but it could be something i would do shortly if it will increase reliability |
You might as well go ahead and do the studs while you have it all apart. It is still possible that even with new studs you can blow your heads again but it will reduce the chance ALOT. It will be worth the money.
ok. what is the advantage of this over just blocker plates?
Getting the coolers off the truck prevents any flash boiling that occurs with them on the truck. This is actually considered to be one of the culprits of puking. Rob at Dirty Diesel says that it has stopped puking on any trucks he has done them on that puked before the cooler removal. It will also help getting your heat to work faster in the cab.
