whats up so i'm running the 250 tune as a daily driver and wow!!! so as the saying goes... your always curious and want more! so i want to know if anyone is driving the 310 as a daily driver... i'm not looking to hammer the peddel but like the power when its time to smoke a cummings.... so any pros or cons to running the 310 tune as a daily driver?
The "mild" 310 would be just fine for a DD tune. The standard or "aggressive", as they now call it now, is VERY touchy on the peddle. If you'r not driving on a smooth road it is almost impossible to keep the truck cruising w/o bumping your foot off the throttle and making the truck jump violently.
Honestly, I would roll the 275 tune as a DD. The more you beat on it with the 310 the sooner the cab will need to come off....lol |
I own a high performance automotive shop and a dyno. The numbers in my sig. are accurate. I have also dyno'd most of the higher HP tunes, (Spartan only), as well as when each individual mod went on the truck.
As for the lift thing, I didn't have any issues with vibrations after the lift. My only issue is axle wrap from the torque!....lol I have a set of Farm Boy Stage 2 traction bars on he way to fix that though. After you install your lift make sure you go back and retorque everything after you put some miles on the truck. |
you have me all excited because i have the same set up as you and if i can get almost 600rwhp that awsome... how much did the tracttions bars run you? |
they are like 600 bucks!!! but they are 1000% worth it. A must on trucks with any form of lift IMO.
I do know a few guys that like to run the 310hp tune as a DD. One example would be everyone at Spartan! But I will have to be honest with you that I would never recommend running the 310 as a DD. Everyone knows when they call in and talk to us at Spartan, the first thing Donna and I say is if you are going to run the 310 as a DD then we will go ahead and give you the number to Sun Coast! Stick with the 275hp! Trust me a 275hp tune is more then enough to take on a dodge!
Ive been running the 275 tune no tcm now for quite some time and it is the perfect DD (and my truck is a job 1) It's more then powerful enough to step up to the plate against a cummins or duramax... the expressions on their faces are priceless lol
![]() a cummings?? wth is that?? ![]()
