cab off info
Does anybody know how many hours does ford get to pull the cab..Nothing else just cab off. Thanks
Don't know how much the book says, but it takes me about 3 hrs. to drain everything and have it in the air.
Same here, as long as those pesky cab bolts co-operate! Don't you guys have a copy of the FMC procedure?
I don't screw with the cab bolts, I have my own way of doing them and it works every time.
It pays 5.9 for a reg/ex cab. 6.1 for a crew. |
What are you doing using a torch and heating them before you attempt to remove them?
maybe tightens them till they break, i do that at work on demo projects often, faster than torch and pretty reliable not sure if its possible or beneficial on cab bolts tho
Or at least I have a local tech that says he can do one that fast. He has said a few other derogatory remarks about the 6.4 Im not sure I believe either.
I can do a 6.0 in about an hour, 6.4 in under an hour is impossible.
ok well is this a easy thing or do you need major mechanical experiance . I have read the break down a couple times and dont seem to difficult just would like to know peoples opinion that have done it..
also interested
