Started my upgrades... wow!
So I ordered the Spartan and it's coming with the 275 and 310 tunes, and the S&B intake kit too. Because of drop shipping, the air intake came Tuesday and I should be getting the tuner and pipe today. Anyway, I installed the intake last night.
Now, I usually drive anywhere between 60-70MPH into work on the freeway for about 20miles and I have about 7miles of surface streets between home and work. If I really babied it and took off from stops really slowly and really took it easy I might be able to reach about 18.5 on the lie-o-meter which hand calculated is actually about 13MPG in my truck. Just the intake kit installed I got up to 22.3 and by time I hit the surface streets and parked my truck at work this morning it was reading 21.6. That's incredible from just the intake kit alone. I'd be interested in seeing what that calc's out to by hand... Anyone know how that meter calculates fuel mileage? I can't imagine it's complicated and actually measures fuel consumption, does it??? Probably just a simple algorithm? I have no clue anyone have any input on this? Can hardlyl wait to see what that meter says after the Spartan is installed tonight.
I wish you would have done this little experiment the other way. i have the Spartan with 250 but have not done the intake yet. Mileage really is not any different than when the truck was stock.
not trying to burst your bubble...but with just an intake you arent going to see that high of an increase...hand calculate it...fill your tank up, record how many miles you go, refill the tank to where it clicks back off record how many galons you just pumped in...
take miles/gallons and you will get your real MPG...you might see the 20's with the tuning and intake. try that and report back with it and see what you can get |
AFE stage II, got me 1mpg better than stock when I ran it by itself. I took it off for a while while I waited on my spartan (got tired of it throwing codes) and noticed that I did lose the 1mpg. Hand calculated, didn't really see any big difference on the lie o meter though.
you can't go by the liometer, especially after you tune it.
Not bursting any bubbles... as I said - hand calc'd 18.5 on the lie-o-meter is around 13MPG. I doubt it's linear, but if it were that would mean I'm actually getting around 15 or 16 MPG. Possible? maybe, but very doubtful. I won't have time to do a real check with a full tank, as I'll be installing the Spartan tonight.
You guys... I'm not going by the lie-o-meter. I was just pointing out the difference the intake made to it and I'm mostly curious about how it calc's the fuel mileage.
Found this link - Not real informative, but you'll probably get the idea....
WikiAnswers - How do trip computers calculate fuel used against mileage covered Looks like it shows 'averages' on the lie-o-meter! |
Oh you are going to love the Spartan, it will be like driving a whole new truck.
I hand calculated mine back when it was bone stock and it did 13ish + or - depending on the foot. The AFE helped, but not a lot on paper. But the DPF delete, gains 4mpg. If you drive slow like you say you do, and it is mainly highway. I bet you see 18 pretty easy. If you can keep your foot out of it. IF.....you can resist......
